At idle, car's rpms lower after a while and SES light comes on????
Old Jun 23, 2003 | 12:10 PM
ONELOUDKAR's Avatar
Angry At idle, car's rpms lower after a while and SES light comes on????
What could be the problem here? At idle only in park... the RPM's will lower after running for a second and the SES light will come on. It will not do this in any gear, it just happens at idle. There isn't a miss either. Could it be my AIC going bad or a sensor?
helpppp
thanks
-Mike
Old Jun 23, 2003 | 12:24 PM
Gripenfelter's Avatar
Unplug your battery.
Remove your IAC and throttlebody and clean them out thoroughly.
Re-install and try again.
Old Jun 23, 2003 | 12:29 PM
ONELOUDKAR's Avatar
Where is the IAC, isn't that on top of the intake on the side? The intake and everything was just cleaned when I had my valve job done last week. And how do you clean the IAC? Did this happen to you as well?
-Mike
Old Jun 23, 2003 | 01:15 PM
The IAC motor is on the plate on the bottom of the throttle body - the one the two coolant hoses connect to. Check on Shoebox's website... I'm sure he had pictures. You should be able to unscrew the IAC motor without removing the TB, but then all you can clean is the IAC motor. If you remove the TB, there are about 7 screws that hold the plate on. Remove it and clean the passages in the plate and in the TB.
Better yet, before you jump to conclusions, why not get it scanned so you can find out why the SES light is on. Maybe the EGR valve is popping open, and you'll be fixing the worng thing if you rip the IAC stuff apart...... just a thought.... but the SES light and the codes are there to help you find the problem.
Old Jun 23, 2003 | 01:53 PM
ONELOUDKAR's Avatar
thanks, i am going to get it scanned hopefully by this weekend
Noenav
Mar 1, 2019 07:38 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
