HELP! White Smoke!!!!!!
Old Jun 21, 2004 | 08:04 PM
  #16
The radiator should be full to the top. Looks like your coolant is going somewhere and I bet you now know where that is.
Old Jun 21, 2004 | 08:07 PM
  #17
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
ok........ so what causes this.. ****in blown head gasket?
Old Jun 21, 2004 | 08:14 PM
  #18
)2overt SS's Avatar
Very good chance...
I'd put my money on that.
Old Jun 21, 2004 | 08:23 PM
  #19
Originally posted by )2overt SS
Very good chance...
What are other symptoms of a blown head gasket???
Old Jun 21, 2004 | 08:35 PM
  #20
)2overt SS's Avatar
Well I've been lucky enough to have never experience a blown head gasket.
But if you're seeing white smoke comming out of your exhaust.. then you are burning coolant/antifreeze etc.
And if you are burning it, there isn't many other ways coolant can get into the combustion chamber other than via a blown head gasket.
I'm sure there are other things that would cause the same problem.. but a very common culpret is the head gasket.
I'm sorry I can't be of much more help than that.. I simply just don't know. But I'm sure someone else will be able to chime in. You're certainly not the first to have this happen
Old Jun 22, 2004 | 10:07 AM
  #21
Alex 97Z28 M6's Avatar
Poor Chris, you're basically going through what happened to me last year (or earlier this year - i forget). The easiet way to see if you have a blown head gasket is to run the car with the radiator cap off (make sure you fill the radiator) and if the return has bubbles coming out of it, you definately have a blown headgasket. By the time I got mine fixed, my car was consuming about 1-1/2 gallons every 80 miles and it was a small leak!
If you do in fact have a blown head gasket, you can determine which side is blown by taking the valve covers off. Look on the underside and you will see a green tint (since you don't have dexcool anymore, it won't be orange). To make it easier to see, place both valve covers side by side and it should be apparent (although harder to see than orange).
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
