Help!!! Whats the most cost efficient way to have a 10 sec lt1???
Old 09-25-2007, 09:52 PM
99vetteman's Avatar
I currently own a 1999 Corvette, and im planning on getting rid of it for something much much faster. I wish i could make the vette my track car but obviously that would be a little expensive. So im looking to buy an LT1 Camaro to be my project. I would really like for the car to be running in the 10's and i was wondering what advice anyone could provide for in doing so the most costly way. Thanks!!
99vetteman is offline
Old 09-25-2007, 10:12 PM
TobyZ28's Avatar
Heads/Cam 200 shot of Nitrous + suspension will be the cheapest...
TobyZ28 is offline
Old 09-25-2007, 10:21 PM
Advanced Member
Heatmaker's Avatar
Nitrous motor, direct port setup, s(pray) to almighty god.
Heatmaker is offline
Old 09-25-2007, 10:29 PM
Daniel6718's Avatar
if you want me guide it would be a 3200 stall cc306 cam mail order tune and a 125 shot......dont put gears in it and leace on the spray youll get easy tens...at least i did..of course youll need a cold and and long tubes...and a walbro kit...but thats all i had!
Daniel6718 is offline
Old 09-25-2007, 10:30 PM
99SilverSS's Avatar
I doubt this is the right forum but I know a bit about your request.
Cheapest way to go 10's in an LT1. Buy the cheapest Z28/Formula or TA A4 hardtop you can find. Have the LT1 rebuilt. Heads/Cam combo for drag and a few stage nitrous system. have the trans built with a high stall TC. Find a race ready 12 bolt of Ford 9" rear end. Put on slicks and skinnies and you'll get 10's after some tuning.
After getting 10's you'll need a harness and full roll cage. Might as well work the suspension over and put the car on a diet. 9's won't be hard.
Not sure of your idea of cheap but that combo could cost $30K car included.
99SilverSS is offline
Old 09-25-2007, 11:40 PM
SS RRR's Avatar
Other than a diff, why would it be more expensive? With the right heads/cam combo and a good tranny/clutch you could get fairly close to the 10's just because of God's gift to the small block world and because the race weight of a Vette.
SS RRR is offline
Old 09-26-2007, 07:56 AM
Geezer powered's Avatar
You can get the vette there easier then a lt1 then you think. Full bolt on's will have that vette in the mid to low 12's. Add on nice no2 shot with a proper tune and your there.
Geezer powered is offline
Old 09-26-2007, 08:18 AM
T/A lt1's Avatar
I ran 10.80's with a stock LT1 shortblock, LE ported heads/cam, longtubes, stock rear with 3.42's, Th350 with a 3,500 converter and NX 150shot. The car was had Weld wheels with 26x11.5" ET streets and stock suspension. It's not hard to do with a good combo and a little n2o. later
T/A lt1 is offline
Old 09-26-2007, 08:51 AM
Z-RATED94's Avatar
Most cost effective way? Buy one that already runs that ET.
Z-RATED94 is offline
Old 09-26-2007, 09:49 AM
The Engineer's Avatar
I agree, having built my own LT stroker F-Body car from scratch ($$$$)! Good luck shopping!
WD
http://www.racingjunk.com/category/1...rs.html?page=1
The Engineer is offline
Old 09-26-2007, 10:42 AM
SS MPSTR's Avatar
99 C5 won't be too difficult to get into the 10's. A nice head/cam combo and a 200 shot on good tires and some practice should do it.
SS MPSTR is offline
Old 09-26-2007, 11:34 AM
speed_demon24's Avatar
A nice h/c combo on motor should be in the 10's, 9's on a 200 shot.
speed_demon24 is offline
Old 09-26-2007, 01:26 PM
SS MPSTR's Avatar
...depends on a lot of factors.
SS MPSTR is offline
Old 09-26-2007, 03:04 PM
SS MPSTR's Avatar
Originally Posted by robvas
I dunno about all that. Here's probably the FASTEST 6 speed LT1 (Taner)
Best mph:151.84 mph Best N/A Mph: 129.28
9.27@151.20mph N2O 1.33 60'/ 10.54@129.28mph,NA 1.497 60'
If it were that easy, more people would be doing it.
I think he might have been referring to the LS1/C5 application.
SS MPSTR is offline
Old 09-26-2007, 03:31 PM
I'd stick with the vette if I was you
Quick Reply: Help!!! Whats the most cost efficient way to have a 10 sec lt1???
