Help with very bad idle
Old Aug 18, 2013 | 04:54 PM
1FST4GEN's Avatar
So got the motor running but it won't idle for crap. It's backfiring and sputtering like crazy. If I hold rpm at 1300+ it will smooth out. Motor has long tubes no cats no smog pump or egr. Has cc503 cam.
Does this cam throw the PCM of that much to where it will run like this. Very very frustrated and need help please
Old Aug 19, 2013 | 08:30 PM
1FST4GEN's Avatar
Re: Help with very bad idle
Bump for some help please guys
Old Aug 19, 2013 | 11:01 PM
slick1hunting's Avatar
So didnt get a tune for the new cam? Any other mods at the same time?
Posted from Camaroz28.com App for Android
Old Aug 20, 2013 | 05:19 AM
Appears you swapped the the 303 in place of the LT4 HOT cam. As noted above, did you have it tuned? Are you sure you had the dots lined up correctly on the timing set?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
beltrunner
May 17, 2015 10:18 PM
Noenav
Apr 30, 2015 01:06 PM
Chet1185
Apr 26, 2015 04:07 AM
ad356
Apr 11, 2015 10:30 PM
