help! tranny gauge wiring question
Old Jun 12, 2004 | 03:37 PM
94zLT1's Avatar
first..what tool should i use to take out the plug in the tranny and can i just go ahead and do it(no fluid will escape?)
then di i just wrap my 18 gauge wire around the bolt and screw the nut tight?
next
ok when wiring my tranny temp gauge i know theres a....
--wire from sender to gauge
--wire from gauge to ground
--two wires that came attached to gauge (1 ground and the other go in what fuse port?) --and then theres one more wire that goes in the fuse port
what im asking is where does the wire for ignition(it says) go and where does the other go
...on the fuses
theres 2 wires i have to put in the fuse ports which goes where..theres a constant 12V..and a switched 12V
which wire gets which
Old Jun 12, 2004 | 05:23 PM
1msfyter's Avatar
You need the sender to screw into the trans access hole. Also protect the wire in wire loom as you run it to the inside(exhaust etc) I wired mine into the stereo fuse because it comes on with the ignition.
Old Jun 13, 2004 | 10:57 PM
94zLT1's Avatar
where is that fuse?
i can wire everything but i dont know what port in the back of the fuse box to tap into for the "power" wire and the "light" for the gauge ....which wire goes where?
dont i need a constant 12V
and a switched 12V
which wire needs which and where are they (the ports to tap into?)
Old Jun 13, 2004 | 11:44 PM
RED95LT1Z28's Avatar
I put mine in the ignition and it works fine with the lights...it comes on with the lights and dims with them when i dim the panel. I put one to the sender the other to the ground and then the other went to my ignition fuse in the fuse box that was it for me.
Old Jun 13, 2004 | 11:56 PM
94zLT1's Avatar
whats the ignition fuse look like
Old Jun 14, 2004 | 03:40 PM
Sorry i made a mistake i went to the ip dimmer fuse and the pcm ign. fuse in the fuse box with those two wires. The pcm ign. i believe is the switched one and the ip dimmer is the constant i believe.
cmdeshon
Dec 27, 2014 10:06 AM
mattszm6
Dec 14, 2014 07:09 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
x7x7
Aug 15, 2002 06:49 PM
