Help with traction mods! (no tires)
Old May 26, 2003 | 11:34 AM
93Z286Speed's Avatar
Im looking for more traction. simple as that, I hear alot of things that help. But what helps me the most? LCA? Control arm relocation Brackets? SFCs? Tourqe Arm? whats gunna make me say wow, that made a huge difference.. By the way the car is not a T-top car, so theres less flex there. Im sick of blowing the tires off the thing when i get on it in first and 2nd. any imput would be appreicated
Old May 26, 2003 | 03:30 PM
Dragon Racing's Avatar
I know the title of your post says "no tires", but your not gonna have traction that makes you say "wow" unless you get some drag radials or something. You can have all the suspension work in the world, but still have bad traction b/c your on regular street tires.
Old May 26, 2003 | 03:35 PM
drag radials dont do jack for you unless you do a burnout first. I use this car as a street car and VERY rarely sees strip time. Thus i will be using street tires and need suspension mods.. a thank you
Old May 26, 2003 | 03:40 PM
Koby's Avatar
Your best bet is for a set of subframe connectore, lowering spring, LCA relocation brackets, LCA's, and a Strut tower brace. The biggest difference out of all those would be the SFC, makes it feel like a whole new car.
Old May 26, 2003 | 03:47 PM
SFC's are for handling, they arent going to make you hook up. They will keep the car from flexing on a hard launch though (which isnt gonna happen on street tires). And lowering springs are going to make you hook up even less. Strut tower braces are also for handling and wont do a thing for you tractionwise. I'm gonna say LCA's, relocation brackets, and some adjustable shocks up front.
Old May 26, 2003 | 04:11 PM
12SCNDZ's Avatar
Take the front sway bar off..BTW, I run M/T ET Streets on the street, too...So street traction isn't a problem. With no other mods I pull 1.73 60 ft. times. It's enough to see daylight under the driver side front tire.
Frank
Old May 27, 2003 | 06:54 AM
hmmm soo LCA's and LCA brackets it is. im going to be building a 383 this winter and ill have the stock rear end for a bit, thats why im saying street tires. If i get something that hooks good, say byebye to my 10 bolt
Old May 28, 2003 | 07:23 AM
next step.. whos stuff do you recomend for LCAs and LCA drop brackets.. any company im mind? or should i just call up speed inc?
Old May 28, 2003 | 08:16 AM
Lost's Avatar
Spohn has the best deal on relocation brackets. BMR and spohn both make nice LCA's. I bought lakewood's LCA's - they're boxed (strong) but heavy and made of mild steel not chromeloy and they're non adjustable. No, they're not the best thing out there but for my car they're plenty. If you're one of those people who absolutely has to go overkill on everything I'd get a tubular chromeloy piece.. I don't think anyone but the most hardcore dragracer needs and adjustable unit.
Oh, and you realize that this may even hurt cornering? If your car is not lowered (mine is not) and you run the LCA in the lowest slot then the car handles a bit different but it does bite in a straightline. Also, the polyurethane bushings may cause bind which can also hinder cornering ability.
As someone else already said, good tires will go a long way. That doesn't necessarily mean drag radials.. even a great set of street tires will make a very noticeable improvement. If your tires are getting bald replace them. If you're running crap tires replace them. I'd suggest the BFG KDW if you drive in the rain, if your car never sees rain then go with the KD and use the KDWS if your car sees snow action. Other people use the firehawk SZ50's (I think) with sucess. Do a search.
I honestly think tires are the place to start, if you're running a good set then ok.. but if not then don't expect any other suspension work to make diddly squat difference.
My .02
Old May 28, 2003 | 09:57 AM
i have a few sets of tires, i got that covered. Cornering isnt a problem i dont do Autocross or anything of the sort.. all straight line. Car isnt lowered. have GFX thats a little TOO low imo... Where can i get the sphon stuff at or even a good price in BRM
Old May 28, 2003 | 11:50 PM
BMR can be found at almost any place like www.ls1speed.com , www.thunderracing.com ....places like that.
Spohn's website...... www.spohn.net
Old May 29, 2003 | 12:35 AM
LT1ponykilla's Avatar
You could ditch those 17'' wheels and get some 15'' drag style wheels and that would help. Even on street tires you would notice a difference. I know I did.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
C6LS3
Apr 15, 2015 09:50 AM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
