HELP suger in the gas tank
Old Jun 1, 2003 | 08:22 PM
  #16
killer-of-pony's Avatar
WOW guys thanks for the thoughts. i really hope the sugar is just sitting at the bottom. iam having it towed tomarro to the shop and see what they say. i really hope i havent f@ck anything up. and if i find out who did this they will DIE!!!
Old Jun 1, 2003 | 08:41 PM
  #17
RacinLT1's Avatar
We laid this rumor to rest back in high school shop.
Gas wont dissolve sugar as said before. Plus sugar will settle on the bottom,and would somehow have to first get past the sock on the fuel pump,and the sock would also have to be resting in the bottom of the tank in the sugar for it to even try to pick it up.
Then it would have to make it past the fuel filter.
If it did make it past,it wouldnt "carmelize" as some have been led to believe.
Old Jun 1, 2003 | 08:55 PM
  #18
IrocManiac's Avatar
Dont kill him, make him pay for a new 396
Old Jun 1, 2003 | 09:06 PM
  #19
kevkop94TA's Avatar
The miss was most likely a clogged fuel pump or fuel filter, which would cause it to starve under hard use. I hope it's nothing more serious.
Old Jun 1, 2003 | 09:19 PM
  #20
Ghettoraid's Avatar
What about dumping some corn syrup into tank?
Its probably denser than gas, but it would eventually get sucked up...
Old Jun 1, 2003 | 10:49 PM
  #21
Vader's Avatar
Are you looking for advice on how to vadalize a car? Maybe you should go to another board where people like you are wanted - if you can find one.
Old Jun 1, 2003 | 11:45 PM
  #22
faded93bird's Avatar
change the fuel filter and run the pump then change the filter again
or you can drain the tank let it dry then wash it out with water " yes water will deslove suger" then let dry again and re install and make sure you change the filter
the above is how it is done at a dealership also pulling the pump and making sure the sock is clean is a good idea too
Old Jun 2, 2003 | 12:45 AM
  #23
CrippleFightin's Avatar
Find the man that did it and cut his damned heart out!!!!!!
Thats what I'd do. Only a P*ssy F*cks with a mans ride and not him directly. Burn his house down!!!!!
Sorry bout that but there is nothing that makes me madder than someone screwin with a mans ride!
Old Jun 2, 2003 | 01:02 AM
  #24
Johnnynsac's Avatar
If you find out the engine is bad, you can go to your car insurance if you have full coverage and get your engine replaced.
Old Jun 2, 2003 | 01:15 AM
  #25
Ghettoraid's Avatar
I suppose I phrased that incorrectly... Think of it as a "what if" ..
Old Jun 2, 2003 | 01:22 AM
  #26
Antz97ZNJ's Avatar
the rw numbers are comming up a little low...maybe the cars not running the way it should
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
