Help stuck in Lafayette... Freescan info!!!
Old Nov 27, 2003 | 10:12 PM
  #16
JDBlaze85's Avatar
if ur gettin spark from the coil and NOT from the spark plug wires then definately the optispark is dead.
Old Nov 27, 2003 | 10:17 PM
  #17
Holding the pedal to the floor puts the pcm in "clear flood mode". It disables the injectors and because the butterfly in the TB is wide open, it lets in the max amount of air. This gives the plugs a chance to clear out any excess fuel. Once the engine begins to fire, your going to let off on the pedal anyway and things return to normal operation.
If you are getting no spark (you might try pulling a plug and sticking it on the end of a wire and grounding the plug's metal body to be sure), there is a test you can do to see if you are getting pulses from the opti to the coil. (that is, if you have enough tools available)
[edit] I forgot you said you had fire at the coil. JDBlaze85 would be right. Looks like at least cap and rotor (secondary ignition side).
Old Nov 27, 2003 | 10:23 PM
  #18
JDBlaze85's Avatar
i gotta question for ya Shoebox
Do you know how to check the pulse that fires the coil off? at the coil itself. theres always 12V in one prong and the other is the negative. Do you use a test light on the negative terminal of the coil.......or a voltmeter?
HEI chevy and Ford?
Old Nov 27, 2003 | 10:34 PM
  #19
HEI chevy and Ford?
I would imagine a test light connected to the neg side of the coil would probably work.
Old Nov 27, 2003 | 10:48 PM
  #20
twdz28's Avatar
good news my roommate is on his way with all my tools, rollaround, jackstands, jack, and extra opti craps...
i guess for x-mas its time for coil over conversion...
Old Nov 28, 2003 | 02:16 AM
  #21
InjectedSS's Avatar
yup that's what I was thinking of
Old Nov 28, 2003 | 05:47 PM
  #22
T/A lt1's Avatar
If you need some help give me a call. I live near Lafayette and have a shop in Lafayette. I might be able to help you out. I even have a spare opti that could sell you to get you back going. I was keeping it for a spare but if you are in a bind. Call me Clint 337-298-8161 Clint. Later and goodluck.
Old Nov 30, 2003 | 06:02 PM
  #23
twdz28's Avatar
Hey Clint I really appricate the offer... My roomate made it to Lafayette with my tools and so on... It happened to be the rotor in the opti was broken... I will be back in town in a week or so and I will give you a call to find out where the action is... If that's ok???
blac94Z
Nov 4, 2015 01:59 PM
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
CARiD
Sep 7, 2015 08:21 AM
