!HELP! strange noise (LONG)
Old Sep 11, 2005 | 11:43 PM
LT1TAGT's Avatar
Unhappy !HELP! strange noise (LONG)
I have a 94 T/A and I have been hearing a strange noise ...It dose not make any noise at idle or when reved in park....The noise only happens when there is a load on the engine in gear,but the noise is not always there it comes and goes..When the noise is there it increases with engine speed and gose away as less load is on the engine...I have checked rocker adjustment,I only use 93 octane gas because I have a tune so I dont think its pinging,but it kinda sounds like that...Oh and I first noticed this noise after I was running my car and got a code for a bad mass sensor,but I got a new maf so I dont know if that matters I did do some high rpm runs while this code was being thrown I didnt think it was as serious as the maf....PLEASE help Ive checked everything.... THANKS GUYS OH and I know its not an exhaust leak the noise was there before and after header install... SORRY FOR THE BOOK.
Old Sep 12, 2005 | 04:28 PM
LT1TAGT's Avatar
Re: !HELP! strange noise (LONG)
Anyone??? Please help
Old Sep 12, 2005 | 07:42 PM
crazypurgatory's Avatar
Lightbulb Re: !HELP! strange noise (LONG)
Well it does not sound like it but check the flywheel.
It might have a crack somewhere.
Chris G.
Old Sep 12, 2005 | 08:01 PM
LT1TAGT's Avatar
Talking Re: !HELP! strange noise (LONG)
I also thought it might be the flywheel but since it did not make the noise all the time I ruled it out,but I looked anyway and found the problem,my starter is wore out and when I get on the car hard the plunger slids into the flywheel causing the noise....Im so happy to have found the problem Ive been searching for a while...So thanks alot... By the way now I need a starter
Old Sep 12, 2005 | 08:09 PM
glad to here you found the problem.
You might want to put a LT4 starter in since your replaceing it.
And it sounds good too.
Chris G.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
StngStlkr
Sep 6, 2002 05:47 PM
