Help! steering column
Old Apr 20, 2003 | 09:30 PM
tom3's Avatar
Unhappy Help! steering column
I removed the steering linkage in order to lower the steering column to change my ignition switch (3 times this pos breaks down).
Now, I can not put it back! no matter what I try, it doesn't slide in. I need to get my car to run for tomorrow morning
I tried to pry it a bit, but to no avail; I thought about oiling it, but then I'll get it all messy and it's going to be harder to manipulate it afterwards.
Any tricks / ideas would be very well appreciated
Old Apr 20, 2003 | 11:21 PM
There is a "how to" on my Tech Page on replacing the switch by taking out the column. No need to remove any linkage, just the column. For it to go back on, you just have to line it up square. Be careful about prying. You don't want to collapse the steering column. Hope you haven't done that.
Old Apr 21, 2003 | 10:49 PM
Bud M's Avatar
I had a hard time getting the steering linkage back together on my header install because I couldn't get it to line up to slide it back in. So I used a grinder on the edge of the opening on the female part and the end of the male part until I could get it started. Then a little hammering got it back together.
IndyZman
Oct 22, 2015 02:17 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
