Alternator header bolt???
Old Apr 21, 2003 | 04:26 AM
96z's Avatar
96z
Is this the stud with the nut in the middle and a black plastic donut thing? I tried to to put this in both ways and it doesnt want to go without threading the head. How does it go on?Anyone try any other way of doing this?
Do I even have the right part in the explaination above?
Thanks!
Old Apr 21, 2003 | 05:06 AM
magius231's Avatar
it would help to have a bit more background here...are you in the middle of a header install or something that you would have taken multiple bolts/studs out, and are trying to find the right one?
The stud on the passengers side that holds the alternator bracket should consist of the stud, bracket, a spacer and I believe one more nut to hold the bracket in place. Personally on my install I left that whole bracket off, figuring its still held at 3 points which should be fine. I haven't thrown a belt yet...
Old Apr 21, 2003 | 11:12 AM
96z's Avatar
96z
Sorry, yeah Im in the middle of a header install and figured I had the right piece but I couldnt figure out how it went on....I may leave it off too than....
Anyone else?
Old Apr 21, 2003 | 11:22 AM
96ZRDR's Avatar
Did not use mine either, no problems since.
Old Apr 21, 2003 | 11:05 PM
Dragon Racing's Avatar
You'll be fine leaving it off. There is still 3 bolts holding it on.
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
moparman
Feb 11, 2015 08:29 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
