help on some codes please
Old Jun 27, 2007 | 07:42 PM
30th6's Avatar
po131 02 sensor circuit low volts (bank 1 sensor 1)
p1641 manfacurer contrl. auxiliary inputs auxiliary outputs
my car is running so rich it wont hardly run. it started at the track.after i got it scaned i barely got it home.it misses so bad and smells like gas.
any help would be greatly appreciated.
thanks joe
Old Jun 27, 2007 | 10:29 PM
P0131 indicates the O2 sensor voltage is hung up below 200mV. That will cause the PCM to think the engine is running lean, and add a lot of extra fuel. If its a "false" lean indication, it will run rich, as you have described. You need to determine if its a problem with the sensor or with something causing the presence of a lot of air in that side of the exhaust. Swap the pre-cat O2 sensors side-to-side. If the problem follows the sensor, its a faulty sensor. If the problem stays on the driver's side, its too much air in the exhaust, or faulty wiring for the sensor.
P1641 indicates a problem with the primary cooling fan relay control circuit.
Old Jun 30, 2007 | 11:12 AM
30th6's Avatar
I think i may have burned my o2 ext. that will make it read wrong im sure. hope thats all it is thanks Fred
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
