HELP! SES code P0157
Old Nov 17, 2003 | 06:53 PM
ronin013's Avatar
im not quite sure what this means, hopefully it doesnt mean the cat is bad and i need to replace it. the code is "O2 sensor low volts (bank 2 sensor 2). i changed the sensor (post cat coming off the passenger side bank) amd i thought it was a bad leak i had between a pipe connection, which i fixed with a MIG weld, but im still throwing the code after those 2 changes. what to do?
Old Nov 17, 2003 | 08:02 PM
P0157
Heated Oxygen Sensor (HO2S) circuit low voltage Bank 2 Sensor 2
Since you already changed the sensor, sounds like it might be a problem with the wiring.
Old Nov 17, 2003 | 09:24 PM
ronin013's Avatar
how could i check it? is there someway i could get the other part of the wiring harness that the sensor plugs into? im not totally surprised it if the wires got messed up, i never liked the setup how much the wires got twisted when you have to unscrew the sensor and screw it back in. the wierd thing is if i clear the code with my scanner it takes like 20 miles of driving before it lights back up
Old Nov 17, 2003 | 09:30 PM
JDBlaze85's Avatar
the wires are not supposed to twist when u put it in and out. you leave it unplugged, screw it in, then plug it up. perfect wires.
that 20 minute delay is normal for that code.
you need a wiring diagram and check all 4 circuits on the harness with a multimeter.
Old Nov 17, 2003 | 09:32 PM
ronin013's Avatar
getting a multimeter is easy, using it and getting diagrams are another story
BigED
Jun 23, 2015 07:19 PM
Hannibal
Sep 10, 2002 04:25 PM
Hannibal
Sep 6, 2002 05:07 AM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
