Help replacing wp seal on the timing cover
Old Mar 30, 2009 | 12:31 PM
  #16
ACE1252's Avatar
I took a picture of what I used. Be sure to oil up the seal, marker, and wp drive shaft. Be sure the marker is completely flush with the wp drive gear. Keep pressure on the marker when sliding the seal onto the wp drive shaft. The marker is self centering. I made sure to get the name of the marker in the picture so you know which one to buy.
Don't saw into any of the gray part. Just cut off the colored tip.
Old Mar 30, 2009 | 12:54 PM
  #17
crazypurgatory's Avatar
Thanks for the picture Eric.
I got the right type of sharpie now.
But I still don't know how the seal looks when it's on.
That is the rear of the seal when I put it on does it stay like that.
see how it is faceing the engine now.
When I put it on and riped the seal the inside lip went towards the front of the engine.
I hope somebody can explain how this seal sits this for me because I'm not going to break another 10 dollar seal.
thanks,
chris
Old Mar 30, 2009 | 12:58 PM
  #18
wrd1972's Avatar
I always use the drive coupler as my install tool. Just lube it up, slide it on the coupler then slide the seal into position much like using the sharpie.
Old Mar 30, 2009 | 01:02 PM
  #19
ACE1252's Avatar
I tried looking at that and using a socket. I was too scared that it would rip the seal. The marker is tapered and the end is right on top of the size of the wp drive shaft.
Old Mar 30, 2009 | 01:04 PM
  #20
ACE1252's Avatar
thanks,
chris
If I remember right, there are two seals on this seal. One tilts towards the engine and one the other way. I had the advantage of working with wp drive shaft out of the engine(bought a replacement). I also experimented with installing the seal with the timing cover off. Using the above marker, both seals were not turned the wrong way or damaged when installing it. Just make sure the marker is true and flush against the wp drive shaft(no gaps as in my picture). Lube up the seal, wp drive shaft, and marker....that will keep the seals from turning the wrong way.
Old Mar 30, 2009 | 01:52 PM
  #21
OK I'm still lost on the seal.
See how the seal lip faces the engine If I turn the seal around the right way?
Now when I installed the seal that riped on me the lip bent out.
Is it saprose to bend out or stay the same shape that it is now.
Thanks,
Chris
Old Mar 30, 2009 | 02:02 PM
  #22
Thanks,
Chris
It should look like this.
Old Mar 30, 2009 | 03:30 PM
  #23
Angry
OK I got the right type of sharpie lubed it put the seal on and the sharpie does not fit on the shaft I tried to tap in on but it did not go on straight and it cut the seal again.
I'm so tired of this thing I only slept 4 hours last night and the only thing in the way of driving my car is this on seal.
I'm about ready to go postal.
I mean dam the next thing thats going to happen is I will get it all together and there will be a hole in the radiator from all the tapping on this seal trying to get it to sit right.
This is by far the most frustrating I have had to do on this car.
It sould be very simple but it's not.
Chris
Old Mar 30, 2009 | 07:47 PM
  #24
97'Z-28's Avatar
It's not that hard to do.
Just keep pressure on the sharpie and push the seal towards the shaft. When pushing the seal onto the shaft, look on the back side of the seal and if its starting to bend inwards, stop and start all over. I used the same size sharpie as the one posted above and had no problems.
Old Mar 30, 2009 | 10:26 PM
  #25
I just used a deep socket and found it pretty easy. If you over-stretch the seal just a little it will go on then shrink back to where it was and be fine.
Old Mar 30, 2009 | 11:42 PM
  #26
ACE1252's Avatar
You got a sharpie super twin tip and cut off the fine tip? Just like in my picture? I suppose it's possible that they changed the design....but if they didn't..... it should work the way I described.
Old Mar 31, 2009 | 11:20 AM
  #27
OK to make a long story short I had somebody come by and put it on.
They used the water pump cupping to get it on.
Looks right and did not rip like the two I tried to put on.
Now I seam to be missing the O ring on the water pump shaft.
Does any body know what size it?
I can get it at the parts store by me.
Thanks,
chris
Old Mar 31, 2009 | 11:24 AM
  #28
Eric I got the bigger round sharpie I did not see your post before I went to the store.
The cover on the sharpie was just a hair too small thats why I would guess the seal riped on me.
Thanks,
chris
Old Mar 31, 2009 | 01:05 PM
  #29
OK so I used one of the old opt spark o rings on the water pump cupping.
I just use it on the engine side because it went on very tight and I'm afraid if I put one on the water pump side I will have a problem taking the water pump off if I ever have too.
chris
Old Mar 31, 2009 | 01:19 PM
  #30
You are supposed to grease the water pump coupler.
