Help! Replacing the spindle... im clueless
Recently got into an accident and the guy at the shop told me i had a bent spindle... i picked up a new one and am going to replace it... i've never done anything like this before, any tips or suggestions? I pulled the wheel off last night and was checkin it out and it just looked like simple bolt off bolt on stuff...
thanks
thanks
Get the TQ spec's for the caliper bolts and other key components, as you want these TQ'd properly. It is a fairly straight forward project, just take your time since it is new to you. You will probably need to have the front end aligned after the work is done.
