Help Removing Starter
Old Nov 23, 2005 | 11:50 AM
Chevrolet Bailey's Avatar
Unhappy Help Removing Starter
94 Z/28 got the starter bolts and 2 wires lose do you have to drop the exhaust to get the starter off. Thanks
Old Nov 23, 2005 | 12:04 PM
Mean Green's Avatar
Re: Help Removing Starter
you shouldn't have to drop the Y pipe. it takes some man handling, but it should come out of there.
Old Nov 23, 2005 | 12:53 PM
OBE1 95Z28's Avatar
I was able to get mine out towards the front but it took some effort. If you haven't already, disconnect your battery terminal.
Old Nov 23, 2005 | 01:00 PM
Muncie4sp's Avatar
definatly disconect your battery. i got mine out as well but it took some time and patience.
Old Nov 23, 2005 | 01:44 PM
I finally got it out but i could not bring it out the front had to bring it out between the exhaust and the transmission lines it was a bitch cant wait to put it back in.
Old Nov 23, 2005 | 01:45 PM
69gto96z's Avatar
I have dropped the starter both ways, and IMO, the time saved from dropping the y-pipe was well worth it.
Old Nov 23, 2005 | 03:07 PM
The way my exhaust bolts looked i dont believe i could have got them loose without breaking the studs off.
Old Nov 23, 2005 | 05:39 PM
cammed_aro Z28's Avatar
carefully bend your tranny lines a little bit and it will fit thru that hole without a problem if you have it twisted the right way. make damn sure you have the little red wire on the correct small post or the first time you start the car, the starter will stay spinning even if you take the key out. have a friend ready with a 8mm ready to dissconnect the battery the first time you start it.
DSMKilla
Jun 11, 2015 05:02 PM
Jun 6, 2015 08:27 AM
lt1matt
Mar 21, 2015 07:35 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
thenewkid
Nov 18, 2014 12:57 PM
