help quickly w/ electrical neon light problem
Old Sep 7, 2003 | 12:51 PM
havoq's Avatar
Unhappy help quickly w/ electrical neon light problem
Ok I have a bit of a problem here. I have two neon lights under my seats. and they turn on by a way of a switch. You have ur positive lead, ur negative lead with a turn on lead, and a battery lead. All fed into a switch that lights up.
Anyways, my girlfriend was moving it around to adjust her seat, cuz it was in the way...it turns out, something happend and smoke came about... so I quickly shut them off.
I looked at it today and the light that she touched, the postive lead melted itself into the negative lead, which prob caused the smoke
ANYWAYS, i cant get the lights to work now anymore. I never hooked up a fuse to the system either.
The lights do work though, cuz I hooked them right up to the battery under the hood and they light up.
What could be the problem?!?! I checked all fuses in the glove box and under the car. Everythign is fine..
uggg
Old Sep 7, 2003 | 01:00 PM
ianfromMA's Avatar
you know you're going to get **** for this....
WHY THE **** DO YOU HAVE NEONS IN A CAMARO!?
just thought i'd start the bashing
Old Sep 7, 2003 | 02:00 PM
96 WS6's Avatar
I shall continue the bashing by saying that neons of any sort, anywhere, on any car are ridiculously pathetic. They are only for D heads that need something to look at when they are D'ed up.
Back to the problem, a wire could have melted somewhere or the switch is bad. That's all I can think of.
Old Sep 7, 2003 | 02:04 PM
havoq's Avatar
well theres no need for bashing because its not ur car and really not ur business. I like it, and everyone who rides in my ride likes it.
Anyways, back to the problem folks...
Old Sep 7, 2003 | 02:19 PM
NOMAD's Avatar
Cool
Check to make sure the switch isn't FUBAR. I hooked up some fans on a buddies car and the switch went to crap and melted in my hand. Ouch ! Get another switch
I like neons if they are done correctly. My white car looks quite ghostly rolling down the road on a foggy night with 2 very small neons
BTW, fuse EVERYTHING !!! An inline fuse is cheap and is a guarantee you won't f' much up
-Shannon
liamcg97
Nov 25, 2019 05:55 PM
97z28k&N
Jan 9, 2015 04:58 AM
Jazsun
Dec 29, 2014 12:14 PM
Zomie
Sep 2, 2002 09:04 PM
