Help Quick
Help Quick
AFTER REMOVING AND CLEANING MY TB AND IAC,,, PUT EVERYTHING BACK ON AFTER 5 HOURS OF HARD WORK...
STARTED THE CAR,, FINE,, THIRTY SECONDS LATER TEMP GOES ALL THE WAY UP TO 255 EVEN THE ENGINE IS COLD.. WHAT IS GOING ON PLEASE HELP.
You need to bleed your coolant lines.
Use the brass plugs that run from the Radiator over to the engine. Unscrew them a little and let the air bleed out. You have air in your coolant lines.
Originally posted by licerio
HOW LONG SHOULD I UNSCREW THEM FOR, ENGINE ON OR OFF...DO I HAVE TO DO THEM AT THE SAME TIME...I DID IT ONCE AT A TIME FOR MAYBE 30 SECONDS...ENGINE OFF AND STILL THE SAME.
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
