Help Quick
Old Feb 20, 2004 | 06:16 PM
licerio's Avatar
Help Quick
AFTER REMOVING AND CLEANING MY TB AND IAC,,, PUT EVERYTHING BACK ON AFTER 5 HOURS OF HARD WORK...
STARTED THE CAR,, FINE,, THIRTY SECONDS LATER TEMP GOES ALL THE WAY UP TO 255 EVEN THE ENGINE IS COLD.. WHAT IS GOING ON PLEASE HELP.
Old Feb 20, 2004 | 06:56 PM
licerio's Avatar
OKAY TEMP GAUGE SAYS 250 BUT HEATER BLOWS COLD...AFTER CLEANING TB AND IAC.. WHAT THE HELL
PLEASE PLEASE HELP
Old Feb 20, 2004 | 07:04 PM
FastWhiteTA's Avatar
You need to bleed your coolant lines.
Use the brass plugs that run from the Radiator over to the engine. Unscrew them a little and let the air bleed out. You have air in your coolant lines.
Old Feb 20, 2004 | 07:07 PM
licerio's Avatar
WHERE IS THAT LOCATED AT? SPECIFICLY..PLEASE.
Old Feb 20, 2004 | 07:11 PM
http://shbox.com/1/bleeders.jpg
Old Feb 20, 2004 | 07:17 PM
licerio's Avatar
HOW LONG SHOULD I UNSCREW THEM FOR, ENGINE ON OR OFF...DO I HAVE TO DO THEM AT THE SAME TIME...I DID IT ONCE AT A TIME FOR MAYBE 30 SECONDS...ENGINE OFF AND STILL THE SAME.
Old Feb 20, 2004 | 07:30 PM
JoeliusZ28's Avatar
bleed them until fluid comes out. engine on.
and the third button up on the left
Old Feb 21, 2004 | 10:39 PM
pearlpurple's Avatar
watch the OPTI
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
