Help! Questions about Cam & Timing Chain
I just got done sliding my new cam into position and the intake is back on. I'm now ready to install the double roller timing chain. I bought CMS's version of the double roller. It has 3 key ways. One has a dot, one has a (-) and the last one has a (+). I'm guessing I want to install it with the dot over the key. The cam I put in is a Comp Cam 236/242 .555/.576 112+4 lsa. I was told by CMS the cam was ground with the +4 and I don't have to degree the cam. Does that sound right? Am I supposed to leave off the reluctor ring?
Re: Help! Questions about Cam & Timing Chain
Before you fix the crank sprocket, remove the stock sprocket key and get one from a 95- car or machine your's to that slot length. Line the dot on the sprocket and leave out the reluctor. You have to get a hub from a 95-, it's longer and should take up the space the reluctor left for a proper pulley alignment.
You should always "degree" the cam in the sense of being sure it is installed at the centerline you want, which in this case is "straight up". This causes a lot of confusion because the term "to degree a cam" has two alternate meanings. One refers to intentionally installing the cam either advanced or retarded. The other is just a measuring process to be sure it is "straight up", as it should be if everything was machined correctly and you install it with the marks lined up.
Rich
Rich
Why would you want to leave the reluctor wheel out and have to get another hub or build a spacer?
I was doing some searching around on the board and it looked like the reluctor wheel has to be removed if you switch to a double roller becasue there is no room for it. I was also told the CPS will not work. I'm guessing it's because you have to remove the reluctor wheel. Am I right about this?
