Help Plz
Old Jul 3, 2008 | 12:04 PM
Bails098's Avatar
Help Plz
i have built 355 LT1 8.1 compression afr 210 race heads, 620 inch solid roller cam 1.6 roller rockers 58 mm throtlle body edelbrock LT4 intake cooks big tube headers msd distributor, vortech supercharger 18 pound boost.
I have 65 pound injectors are these a good size for my mods?
Where can i get a computer and tune to run this car, i live in ontario anywhere i have called do not wanna touch it to tune it.
Old Jul 3, 2008 | 12:10 PM
ulakovic22's Avatar
What FP are the injectors rated at? Most are rated at 43.5 and boost referenced they will see more as the boost comes on. I think they will be on the low side of what you need, but if you already have them I think you can run them to see where you are at.
If the injectors a high impedance then you can run a stock computer and get it tuned anywhere. If they are low impedance then you need a convertor to run the stock PCM or aftermarket.
Old Jul 3, 2008 | 12:39 PM
Bails098's Avatar
Most places are saying that because of the size of the cam they wont touch it for a tune.
Old Jul 3, 2008 | 12:47 PM
BUBBA's Avatar
Well, those 65s are probably good for at least 900 HP at the crank. I don't know how you arrived at the 65s---if someone recommended them, I would be curious to know on what basis. 42s are good up to around 600. You will need to have the PCM programmed for the the constant injector pressures.
Once you decide which injector size, you can contact PCMFORLESS and they can probably give you a mail order tune for your setup.
Ingineer is the expert when it comes to this stuff. JMHO
Old Jul 3, 2008 | 01:09 PM
Bails098's Avatar
I did contact PCM4less the said because of the size of the cam they will not do it unless they had the car there.
Old Jul 3, 2008 | 04:29 PM
The 65's are good for more like 800HP at the flywheel. A blown engine has a higher brake specific fuel consumption, due to the need to run richer under boost, and to compensate for the fact the blower is pulling power off the nose of the crank.
Get it dyno tuned. You don't run 18# of boost with a mail order tune.
colts0455
Sep 11, 2015 06:16 PM
Jmj93z28
Jul 8, 2015 10:01 PM
BigTed187
Oct 7, 2003 03:34 PM
drewstealth
Jun 18, 2003 04:31 PM
ChoderBoy84CamaroZ28
3rd Gen / L98 Engine Tech
13
Mar 24, 2003 06:56 PM
