help please help, asap!!!!
Old Apr 14, 2007 | 12:12 PM
irishz28's Avatar
here is the deal. im trying to put an ati dampener on my 383. i have a cloyes true double roller timing chain. its a 96 so it had a crank reluctor ring, and it has been removed. do i still need to use the spacer or does the new crank sproket make up the diffrence?
Old Apr 14, 2007 | 12:55 PM
WS Sick's Avatar
measure the thickness of both gears.
Old Apr 14, 2007 | 12:59 PM
Colin91Z's Avatar
You'd be better off using the earlier style crank hub, thats what I ended up doing when I ran into the same sitution.
If you need one, I have an extra by the way...
Old Apr 14, 2007 | 01:18 PM
irishz28's Avatar
i have allready installed the gear and the timing cover. i just learned about the spacer needing to be there. i made a spacer out of my reluctor ring, i just need to know if i really need it or not. the minute that i get confirmation of wether i need to spacer or not, the balancer is going right on the engine.
Old Apr 14, 2007 | 01:29 PM
Colin91Z's Avatar
If thats the case, then yes you'll need the spacer that you made.
Old Apr 14, 2007 | 01:44 PM
irishz28's Avatar
thanks alot. youve really saved my a$$ on this. your the man.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
