Help Please!! Fuel pressure regulator...fuel spraying out
Old Feb 8, 2008 | 10:46 AM
brokencar's Avatar
I have been trying to solve my fuel pressure regulator problems on a 1997 TA. I've already removed the entire fuel rail and came to this conclusion...I have an aeromotive adjustable one and it doesn't have clamps to connect the fuel line to the regulator....Does anyone know where I can get one of these clamps...or modify it....Thanks
Old Feb 8, 2008 | 10:59 AM
The Engineer's Avatar
The Areomotive regulators have a port for a pressure gauge which requires a plug if it isn't used. My Aeromotive was missing that plug.
Also, Aeromotive makes a regulator for the LTs which should be a bolt-on without any modifications. Here is a photo. Notice the plug in the Red body of the regulator.
WD
Old Feb 8, 2008 | 11:39 AM
brokencar's Avatar
WD
Hi, I'm missing the clip right there at 2 fuel lines that holds it inside...ANy idea where to get one?? Thanks
Also what size disconnect to use on the linnes right there..mine are still connected...Thanks
Old Feb 8, 2008 | 11:46 AM
ss.slp.ls1's Avatar
You can buy a set of plastic disconnect tools at AZ for a few bucks, has 3 or 4 different sizes.
Old Feb 8, 2008 | 12:14 PM
Supply line is 3/8", the return line is 5/16".
The bracket that holds the two fuel lines is not what "holds it inside". There is a small C-clip that slides over the flange on the fuel pressure regulator and the flange on the fuel line. You can see the edge of it in the photo. There should also be an O-ring on the end of the fuel line.
Old Feb 8, 2008 | 02:10 PM
brokencar's Avatar
Thanks, Looks like I'm missing the C-clip...I took off the entire fuel rail and got everything nice in tight except the plug in back of aeromotive is leaking so I need to find a new one....Any idea where to find these c-clips...or should i make my own custom clamp??
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
