Help Please
Old Jan 9, 2008 | 12:09 PM
z28camaro1090's Avatar
Help Please
This morning i went to start my 1993 Camaro z-28 and it would not start. when i turn the key i hear a click i am assuming thats from the starter. can anyone give me any help as to what this problem could be? I was thinking fuel pump, starter, or maybe even the distributor because I know they have a tendency to go bad on this car due to poor design. Any insight is greatly appreciated
Old Jan 9, 2008 | 12:12 PM
LT1CST's Avatar
I would start with the battery. When you turn the key on. What does the Battery Voltage read? If the battery is low it will not start. You need alot of cranking power to turn the Starter to crank the motor. So I would start with the battery.
Chris
Old Jan 9, 2008 | 12:15 PM
the voltage is reading between 10-14 i cant really tell exactly. but i am not getting any crank just a click
Old Jan 9, 2008 | 12:17 PM
mdacton's Avatar
I may only click if you don't have enough volts...try to jump it
Old Jan 9, 2008 | 12:19 PM
ok thanks i have to get someone to give me a jump right now no one else home besides me so it seems like im gonna have to wait a little bit
Old Jan 9, 2008 | 12:20 PM
BUBBA's Avatar
Do your headlights work? It may be bad connection(s) check both the terminals and the wires. Most cases=bad batteries. JMHO
Old Jan 9, 2008 | 12:24 PM
thats the weird part my alarm sets and sounds nice and loud.. thats why i wasnt thinking the battery
Old Jan 9, 2008 | 12:26 PM
i just checked the headlights come on i cant tell how bright they are due to its really sunny out and i dont have a dark area.. but i can tell they came on
Old Jan 9, 2008 | 12:32 PM
Alarms and lights have a current draw ranging from a fraction of an amp to 30 amps. The starter pulls several hundred amps to start the engine. A battery strong enough to power the alarm and lights might not be able to supply the amperage required to start the engine. Could be a weak battery, could be faulty/corroded main cables and battery terminals, or a dead starter/solenoid.
You have to rule out the battery first.
Old Jan 9, 2008 | 12:35 PM
ok.. i am working on finding someone to give me a jump right now.. lets see how that goes.. hopefully it works
Old Jan 10, 2008 | 12:31 PM
LT1CST's Avatar
I would take the battery to Autozone and get it tested just to make sure. It sounds like your Starter has Failed. However a click means not enough power. To me it sounds like a starter.
Chris
Old Jan 10, 2008 | 12:38 PM
BUBBA's Avatar
If your battery is close to or past the expiration date or is completely drained and needs a charge then my quess is that it is your battery.
I'll bet. Anyway let us know.JMHO
