HELP plastic blocks fell off oil ring
Old May 12, 2004 | 06:35 PM
526 SS 96's Avatar
Hi, I am assembleing an engine, and my courigated oil controll ring lost 1 or both of the plastic blocks, is this anything to be concerned over. I think they are only to aid in assembly, but I am not sure so I thought I would check.
Aleks
Old May 13, 2004 | 07:00 PM
arnie's Avatar
Ring mfr. should have a tech line. At the least, this is a bump.
Old May 13, 2004 | 09:30 PM
Rodrigues's Avatar
I would definetely have them replaced, it may aid in not scratching the cylinder walls and giving it the proper tension
Old May 14, 2004 | 09:21 AM
526 SS 96's Avatar
I finished installing the pistons. I went ahead anyway, because I can't see how they would affect anything. I think they are there just to aid in the installation because when they are not there it is easy to overlap them, but I checked and re checked, and I am sure they are properly butted together. I could be wrong though, so if any one knows other wise please tell me.
Aleks
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
