help on pistons rings install
Old May 24, 2008 | 10:24 PM
Sporty-X's Avatar
hello, i'm installing new pistons rings and lost the paper there was in the box.
Rings are speed pro and have both a notch on a side. I just want to know if the notch is for top side for both rings ?
Pierre
Old May 25, 2008 | 10:38 AM
sandman2100's Avatar
notch or bevel? Always point the bevel or notches on the rings up if that is what you are asking. If you're asking if where on the piston the notched ring goes, off hand I think that is the second compression ring, but I can run out to the garage and check.
Old May 25, 2008 | 11:34 AM
Z28LT1_Just_Nasty's Avatar
The rings with the white dot right? They face up.
Old May 26, 2008 | 05:42 AM
Sporty-X's Avatar
yes, it was dots. i put dots upwards for both rings.
thanks for your help
Nov 18, 2023 07:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1963SS
Feb 6, 2015 10:05 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
