help on pistons rings install
hello, i'm installing new pistons rings and lost the paper there was in the box.
Rings are speed pro and have both a notch on a side. I just want to know if the notch is for top side for both rings ?
Pierre
Pierre
notch or bevel? Always point the bevel or notches on the rings up if that is what you are asking. If you're asking if where on the piston the notched ring goes, off hand I think that is the second compression ring, but I can run out to the garage and check.
