HELP ???? ON ORDERING 02`s WTF
Old Jan 7, 2004 | 11:05 PM
96ssz28#395's Avatar
OK i have a 96 SS and i have jet hot SLP shorty headers. Which has the factory 2 cats. which then runs into the. Slp 2otl that came with the car from SLP. Anyway i was getting a ses light and had it read at auto zone. Which said low voltage.Bla Bla you know the deal.On bank 2 which i was told this was a pre cat 02 on passanger side. So i was just going to get them both and replace them.So i call Jason Crommer up and tell him the same thing and he tells me that the one i need will be like 60 bucks and that it is in front of the passanger side cat. and i had been told pre cat o2`s are around 30 to 35 bucks from them so what am i missing here that is a price for the after cat 02`s So which 02`s Do i tell him i want.I am thinking tell him to give me the pre cat 02`s and that is that.Because the after cat 02`s are for the reading of the cat`s. and i have no bad codes on thoes.If i am not getting something here Please let me know. Thanks For Your Time. Mike....
Old Jan 7, 2004 | 11:20 PM
97LT1SS's Avatar
You should have 4 sensors all together, the 2 that are in front of the cats have different plugs than the ones after the cats. I have paid $50 to $60 bucks for Bosch sensors. I don't know if I have helped out or not, good luck.
Old Jan 7, 2004 | 11:25 PM
The pre-cat O2s should be ACDelco #AFS75, GM p/n 25312184 and should be ~$35 wholesale. Maybe Jason told you cost for both sensors on one side.
Old Jan 7, 2004 | 11:34 PM
Yes i know They have differant plugs. But Jason said that the one before the cat on the passanger side is what i need but it would be like 60 bucks i ask again. With the same response when i am sure.That 02 is a pre cat 02 and should only be 30 to 35 bucks from them.Unless i am just missing something on the type set up i have. Which i should not be. code said bank 2. O2 and showed pre cat 02. Thanks for the input. I just want to make sure before i order.
Old Jan 7, 2004 | 11:41 PM
Thanks shoebox. I think i am just gong to order the two pre cat 02`s like i was going to do and be done with it. and when i change those i will take out the after cat 02`s and just clean thoes up and throw them back in.I think this should cure all my troubles.
Old Jan 7, 2004 | 11:42 PM
97WS6SCharged's Avatar
Hey, if Jason won't sell them to you at cost, go to http://www.gmpartsdirect.com and put in the part number that Shoebox gave you. You can get two of them shipped for $85 bucks.
Old Jan 8, 2004 | 12:54 AM
drewstealth's Avatar
Just call Jason up again and tell him you need 2 of the front o2 sensors. I ordered 2 of them yesterday from him at $35 each.
n2oblkz
Oct 22, 2015 02:31 PM
Stephen68
Oct 16, 2015 03:50 PM
n2oblkz
Oct 12, 2015 01:53 AM
Bxlt1
Sep 29, 2015 03:18 PM
