help this noob out!
Old Aug 10, 2004 | 01:57 PM
irocket87x's Avatar
help this noob out!
I have just bought a lt1 motor from some guy that got it out of a 95 vet that i plan on putting in my 87 z28. He said that i need a harness and comp...what system do i go with cause i herd of the obdI and obdII but i dont know the difference between the two. I also dont know if i should get the painless wiring harness or not cause of the gauge wire.would that matter?
thanks
bobby
Old Aug 10, 2004 | 02:03 PM
944v8inDFW's Avatar
Re: help this noob out!
Check my sig as i am a transplanter too. You can use a 94-95 harness corvette, fbody or impala will work. No matter what you will have to reprogram your PCM. I would try to find a 94 if possible just for the fact of the programming plug. 95 is and odb1 with an obd2 plug. You could actually use a newer harness if you feel like taking a few things out. Newer harness older (94 -95) PCM. IMO after 6 transplants the painless just aint worth it if you can do some basic stuff yourself. I would plan on a programming cable so you can program out VSS, EVAP, VATS, EGR and so forth. Much easier than the painless modules.
Old Sep 2, 2004 | 09:07 PM
irocket87x's Avatar
thanks u really saved me some time
blkWidow
Apr 20, 2015 09:27 AM
Xvirus
Apr 22, 2006 04:36 PM
always faster
Apr 4, 2006 12:34 AM
