Help Needed,Timing Cover, Distributor Issues
Old Jun 26, 2020 | 06:06 PM
Robb676's Avatar
I went to close up the front of my new engine with the timing cover and was having a issue with the gaskets that I ordered. I ordered gaskets and a new distributor for a 1997 LT-1, as I was told 1995-1997 engines were all the same. Well, I found out there not.
The engine that is going is I was told is a 1995 LT-1, It is going in a 1997 Z28.
Can some one look a my photos and tell what I am doing wrong? I probably can not return the new parts I bought but it is a lesson learned. Thank you.
New Motor Front
New Motor Timing Cover Right Side Up
1997 timing front
Old Jun 26, 2020 | 10:06 PM
Re: Help Needed,Timing Cover, Distributor Issues
The cover in the middle picture is for a non-vented (93-94) opti. If that came off your "new" engine, then it was not a 1995 or later.
Old Jun 27, 2020 | 05:07 AM
Robb676's Avatar
Can I just switch covers to use the bottom one? Are they interchangeable?
Old Jun 27, 2020 | 07:23 AM
Yes, as long as your cam and cam gear are not of the splined drive type that was used with the earlier opti.
Ekof96Z28
Parts Wanted
Jul 14, 2008 01:07 PM
Black6spdZ
Jan 23, 2007 06:33 PM
roadtrip120
Parts Wanted
Dec 28, 2004 09:44 PM
Brandon 95 Z28
Jan 19, 2004 12:19 PM
