HELP with Melling oil pickup
Old Jul 9, 2008 | 11:42 AM
BLDun's Avatar
I purchased a Melling 10554 from Summit and a pick up tube. When the tube came it was a bolt on type and so it won't hook up to the pump. Summit said they don't stock the press in ones. Anyone know where I can get one asap???
Old Jul 9, 2008 | 03:33 PM
Dealer or parts store.
Old Jul 9, 2008 | 05:07 PM
BLDun's Avatar
So, its the same as a stock one??
Old Jul 9, 2008 | 05:16 PM
You tell me. Does it look like it would press in like the stock pickup?
Old Jul 9, 2008 | 07:55 PM
BLDun's Avatar
It looks like it should. In fact I would use the one from the pump I took out except that someone spot welded it in.
Old Jul 9, 2008 | 07:57 PM
FlamingChicken's Avatar
ill be honest summit techs know dick and the customer service reps know alot less. are you sure it doesnt just have a support bracket that bolts to the housing and the pickup is still a press on? i know thats how mine is.
Old Jul 9, 2008 | 08:12 PM
BLDun's Avatar
I thought about that but there aren't any bolt holes in the housing for it to bolt to. It is a press in one and when I called Summit the guy had to call Melling to find out which pick up went to it and then told me they didn't stock it but if I was willing to wait 3 - 5 days they could get it. I just called Jegs and they had one and said they will have it to me tomorrow.
Old Jul 9, 2008 | 09:10 PM
jclark311's Avatar
Here is what i used
Oil Pump GM 93442037 74.79
Oil Pump Shaft ARP 134-7901
Pickup GM 12550042 10.86
White Spring GM 3848911 2.32
Oil Pump Drive Assembly GM 1103868 42.73
Works great 60lbs on cold start, 25lbs when hot, its the Melling select, i bought it from GM Parts Direct, if you are changing your pump, you might want to think about changing the Oil Pump Drive if you have a lot of miles on it
Old Jul 9, 2008 | 09:29 PM
BLDun's Avatar
I pulled the oil pump drive and it looks hardly worn and the motor only has about 10,000 on it since the rebuild.
Old Jul 13, 2008 | 10:02 AM
johnnyb's Avatar
If you didnt get it by now, autozone sells what you need for i believe under 10 bucks
Old Jul 13, 2008 | 01:22 PM
BLDun's Avatar
I got it yesterday and installed it and it is working like a champ!! Borrowed a priming tool from Auto Zone and primed it - didn't take too long and now it runs about 60 - 65 at idle when cold.
94Form
Jul 17, 2015 10:56 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
Slayer
Jul 4, 2015 03:06 PM
