help me! why is my car backfiring?
Old Aug 10, 2003 | 06:48 PM
cridom's Avatar
i think my car is backfirering because it like redlines at 4500-4600 under load and i dont know what it is.
what should i do to fix this? tune-up?
btw it only has like 50k miles
Old Aug 10, 2003 | 06:57 PM
Mizz96Z28's Avatar
What do you mean by "it redlines at 4500-4600 RPM's"? Do you mean no matter what it won't go past that RPM range? Describe your situation more and you should get better responses.
Myles
Old Aug 10, 2003 | 07:06 PM
Geezer powered's Avatar
optioptioptioptiopti
Old Aug 10, 2003 | 07:48 PM
cridom's Avatar
not always for sometimes when i race i hear this explosion underneth the car and te car hesitates and a little black smoke comes out
this is only when i floor it
it doesnt seem as fast anymore it like lost power
also sometimes when launching (m6) it hasitates
Old Aug 11, 2003 | 04:28 PM
cridom's Avatar
how can it be the cat? if u got no cat it gives u more power
Old Aug 11, 2003 | 04:37 PM
ChevyIron's Avatar
Check your fuel pressure mine did the same thing backfire like you describe.My fuel pressure was too low turned it up and backfire went away.How old is your opti did you recently do any work around the opti involing water If so opti might be bad.Also check your ignition If you have an aftermarket ignition unplug and plug your stock onre in see if that helps.Good luck
Old Aug 12, 2003 | 03:37 PM
Getsome17's Avatar
When I bought my car it wouldn't rev over 4500rpm in third gear. It felt like when you hit the rev limiter. Anyways I changed the plugs and wires and the car came to life and I haven't had any problems since.
bfmv13trivium
Jan 14, 2015 09:57 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
