Need Help...asap
Old Aug 11, 2003 | 10:22 PM
1994TransAm's Avatar
Need Help...asap
big problem guys,
okay i installeda 224/230 in my 94 LT1. i tried to program the car and i get a ""incorrect respose from PCM".
i'm using a cats windows program and AKM cable. program from PCMFORLESS.
what does this mean, the second try says
" no response from PCM"
i unhooked the battery and pulled the PCM battery fuse?
i donno whats going on, woodward is saturday. what am i gonna do!!!!!!!!!!!!!!!!!
Old Aug 11, 2003 | 10:32 PM
Try another program like Freescan or an evaluation download of TTS Datamaster to see if your cable works with that.
Old Aug 11, 2003 | 11:00 PM
can i wreck a pcm by hooking up the battery?
Old Aug 11, 2003 | 11:08 PM
97Z-M6's Avatar
have done programming to it before or has any one else for that matter.
does sit communicate or does it fail to communicate. when does it when does it tell you incorrect responce. are you sure that you have selected the corect ecm file from the tool bar labeled ECM you need to select EE
Old Aug 12, 2003 | 12:25 AM
it doesnt communticate to the PCM.
the fans come on the car if i have a cable hooked up... i think my PCM is courrupted.
Old Aug 12, 2003 | 12:38 AM
turbo_Z's Avatar
pull the PCM fuse and count to 30. put the fuse back in and see if the fans go off. if they dont then you fried the PCM and will need a new one or yours fixed. im sure madwolf can overnight you one and/or fix your old computer.
did you try reading a file first?
edit: sorry i must have missed it when you said it was giving you a "no response from PCM".. its a paperweight
Old Aug 12, 2003 | 12:50 AM
okay so you huys think its my pcm?
i cant read, cant write.......... and if i plug the cable up to the car and dont scan it, turn the ignition on.. the fans run.
if i scan it, i ge tht prompt "No response" the fan stay on all the time untill i shut the car off!!!!!!
i say its the PCM cuz this is my th cam install and i have never had a problem!!!!!!!!!!
Old Aug 12, 2003 | 08:58 AM
Sounds like a cable/physical problem to me. The cable may be shorting the pins you would use to flash codes (if it was possible on a 1994 (it's not)). That would make the fans come on.
Does it make the fans come on if you just plug the cable into the car and not plug the other end to the computer you are using for programming?
Since it does not look like you ever communicated with the pcm, doesn't the engine still run with the old program?
Old Aug 12, 2003 | 02:34 PM
turbo_Z's Avatar
unfortunately i know the signs of a fried pcm all to well and yours is definitely toast. you musta lost contact with it when you got the error "incorrect response from pcm" and that is why the fans now run constantly but the car will not.
did this happen during the first stage of the programming right at the end when it said it was "erasing memory". i have lost a couple pcms with the windows flash utility b/c i tried to read a file off the A drive instead of the hard drive and both times i lost communication while it was erasing the old memory.
Old Aug 12, 2003 | 03:56 PM
thewinner's Avatar
pcm is toast. any time you lose connection with the pcm during a write process, the pcm will die since it erases the program first, and will only have a partial file uploaded when you lose coms with it
