Help me take my stock exhaust off
Old Mar 19, 2005 | 12:51 PM
Munson's Avatar
Im taking off my jethot y-pipe which is hooked into the stock piping and the stock 2otl.. Is there any way I can take the stock piping out without having to hacksaw it off? The clamps have crimped the piping together and its not going to budge.. Any suggestions?
Old Mar 19, 2005 | 01:50 PM
blackz97's Avatar
Re: Help me take my stock exhaust off
Drop the rear end and remove panhard rod assembly. No biggy.
Old Mar 19, 2005 | 01:51 PM
Munson's Avatar
Sweet thanks!
Old Mar 19, 2005 | 04:32 PM
hotrod18_69's Avatar
Well he jumped all over that idea.. LOL
But its not that bad.. droping the rear is easy.
Old Mar 21, 2005 | 02:25 AM
Munson's Avatar
i was being sarcastic any logical ideas would be helpful
Old Mar 21, 2005 | 05:12 AM
30696bird's Avatar
I jacked my rearend (on the car smartass's) REAL high and wiggled it this way and that way till it came out. It was a MAJOR pita! but I got it out! Hope this helps you out.
Old Mar 21, 2005 | 05:59 AM
TransAm396's Avatar
ill buy that from you if you dont want it
Old Mar 21, 2005 | 12:02 PM
Munson's Avatar
306bird what do you mean you jacked your rear end up? u jacked up the body or the actual rear end?
Old Mar 21, 2005 | 12:06 PM
TransAmGT's Avatar
the rear of the car...not the rearend...you want the rearend(axle) the be as low as possible!
Old Mar 21, 2005 | 12:14 PM
Z28Horn's Avatar
jack up the rear end of the car, not the actual rear end, so the rear suspension is completely lax, there should be enought clearance for you to work the exhaust out of there.
Zach Horn
A.C.S. Inc.
Old Mar 21, 2005 | 01:39 PM
30696bird's Avatar
Zach Horn
A.C.S. Inc.
This is what I meant........
Old Mar 21, 2005 | 03:29 PM
TransAm396's Avatar
if theres not enough room..just remove the shocks but support the rear..that will give you the rest of the clearance you need.
Old Mar 21, 2005 | 06:39 PM
Munson's Avatar
Where do i need to put the jackstands in the rear to do this?
Old Mar 21, 2005 | 07:24 PM
transambill's Avatar
Just forward of the front lower control arm mounts.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
