help me pick a cam for 385 stroker
Old Jun 10, 2006 | 02:19 PM
weaponZ's Avatar
street and strip cam.shooting for low 11's.
block is a lt1 bored .40
heads are AFR210
mahul pistons
eagle h-beam 6.0 rods
eagle 3.75 crank
thanks in advance
Old Jun 10, 2006 | 03:48 PM
The Engineer's Avatar
Re: help me pick a cam for 385 stroker
I'm going with one of the new Comp XFI cams for my new LT 396 stroker. 242 Int/248 Ext at .050 and .584 Int/.579 Ext lift w/ 1.6 RRs. It is the largest XFI LT cam and it has a range of 2200 to 6200, which should be perfect for the stroker.
Additionally, the cam must be a custom grind on a small base circle for the stroker. The Comp core # is 07-000-8 and small base circle grind is #3018/3039 HR113+4. I ordered my cam through Jeg's.
I'm also using AFR LT4 heads and will have about 12.1 to 1 compression and will use PCMforLess programming. I'm also expecting low 11s all N/A.
http://www.cardomain.com/ride/2189634
Old Jun 10, 2006 | 03:56 PM
Jameslt1TA's Avatar
I would just go with a custom cam that is matched to your heads. Only way to do it IMHO. I think you can talk to Joe Overton or Bret Buarer about custom cams. Its only like 100 bucks more to go custom and that is the only way to get your full potential out of your setup.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
Killer94z
Jan 13, 2015 12:06 PM
