Help Me Choose A Spark Plug Wire Set
Old Feb 18, 2004 | 02:30 PM
licerio's Avatar
WHERE DO I GO FOR SPARK PLUG WIRE SET AND WHICH ONE IS GOOD FOR A STOCK Z28(1994 A4). I NEED THIS LIKE BY FRIDAY.
LINKS WOULD BE GREAT! THANKS
Old Feb 18, 2004 | 02:34 PM
licerio's Avatar
spark plugs also,, what and where to get them.
Old Feb 18, 2004 | 02:39 PM
Fastbird93's Avatar
Thunder Racing sells a nice over the valve cover kit for $100, and NGK TR55 plugs gapped at the stock range are a pretty good match.
Just my $.02, and I'm running the exact mentioned setup on both of my cars.
Old Feb 18, 2004 | 02:49 PM
licerio's Avatar
whats their website? and where do I get the NGK plugs? can I get them at autozone?
Old Feb 18, 2004 | 02:52 PM
You don't want OVC wires for a stock car.
Old Feb 18, 2004 | 02:53 PM
licerio's Avatar
I found the website how many spark plugs?
Old Feb 18, 2004 | 02:55 PM
licerio's Avatar
shoebox direct me to the right direction which spark plugs/wires should I get then part number or which one is it from summitracing.com or thunder racing. HELP
Old Feb 18, 2004 | 02:56 PM
OBE1 95Z28's Avatar
I'd recommend staying with the stock platinum plugs for a stock car. They are designed for extended life (75K+ miles). Copper based plugs are great for car with power adders that need the plug to run "cooler" to help prevent pre-ignition, but will require you to change the plugs after on 30K miles.
I like the Accel 9000 wire set. They're 8mm so they'll fit in the stock looms and will handle the heat if you decide to upgrade to headers later. Probably cheaper that stock GM wires (Accels run $69 - $75).
Old Feb 18, 2004 | 02:57 PM
Fastbird93's Avatar
Why not??? Is it just not compatible with the stock manifolds, meaning there's not any clearance for the wires?? That's the only thing I could thing of as a reason not to put them on a stock car.
Old Feb 18, 2004 | 02:59 PM
licerio's Avatar
CAN I GET THIS FROM THUNDER RACING?
04-74226 Taylor Spiro-Pro 8mm Spark Plug Wire Set, 93-95 LT1 Camaro/Firebird, RED
AND
50-TR55 NGK TR55 Spark Plugs, Stock heat range, gapped at .050
I NEED TO ORDER THIS IN LIKE 30 MINUTES...
Old Feb 18, 2004 | 03:06 PM
slider's Avatar
What's the part number for the universal Accel 9000 wire set?
Because you would have to lay them right on the stock exhaust manifolds (since they are above the plugs). You would just burn the wires up. They are for header applications.
Old Feb 18, 2004 | 03:08 PM
licerio's Avatar
AND
Old Feb 18, 2004 | 03:15 PM
licerio's Avatar
Well I ordered this one -->
hopefully its the right one.
AND
Old Feb 18, 2004 | 03:42 PM
sskilla9three's Avatar
i have the taylors...they are good wires.
