help me build a daily driver...badboy...!
Old Jun 14, 2009 | 06:07 AM
felon_gt1's Avatar
Talking help me build a daily driver...badboy...!
so im looking to build a daily driver bad boy well not to bad....but im looking into gettin a le cam and i already have full exhaust including headers and k&n intake...but im still a newb with cars and camaros since im only 20 and this is my second car, but im hearing about porting my heads? i really dont get the idea?....but im here to listen and learn....if i do port them how would that help me and y? also am i better of buying heads from somewhere online or porting my own? let me know guys all comments will help me, thanks
Old Jun 14, 2009 | 10:37 AM
The limiting factor in producing HP is how much air you can stuff in the cylinders. Ported heads (reshaping the intake and exhaust runners) increases the flow capacity of the head's intake and exhaust runners, allowing the engine to take in more air (= more HP, when matched with the required amount of fuel, which is easy to supply) and get the combustion products out of the cylinders faster. Same thing you are doing when you install a cam with greater duration or lift... allowing higher air flow into the cylinders. Same thing you are doing with a cold air intake. Same thing you are doing with a freer-flowing exhaust system. Get more air in, dump out the products of combustion - make it breathe.
The stock heads can be ported to support up to 500HP at the flywheel. It that's enough for you, stick with the stock heads.... it will be cheaper. If its not enough, there are aftermarket heads available that will up the HP level, after they are ported. It takes a lot of skill to make big HP. You would be better off finding someone with a good reputation for producing HP results. The fact that you had to ask the question tells me you may not know enough to port your own heads effectively.
Old Jun 14, 2009 | 04:05 PM
foxbat's Avatar
listen to fred
Old Jun 14, 2009 | 05:59 PM
felon_gt1's Avatar
OH TRUST ME IM LISTENING....ya well i have a buddy i work with that has a 94 383strocker in his z28...and he tells me that the ppl he did his port work are good ppl and they know what their doing, so im prob gonna go with them...but i just needed to understand what it meant first....thaks for the help INJUNEER, it really help me.....
Old Jun 14, 2009 | 10:00 PM
Just for background info, check out head porters like Lloyd Elliott, Advanced Induction and TEA. Proven results.
Novo
Jun 14, 2016 02:58 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
WPHIG2
Aug 27, 2015 06:37 AM
