help! lt1 wont idle right
Old Nov 10, 2004 | 06:38 PM
nonojoe66's Avatar
hey i was wondering if anyone has any sugjestions... i have a 93 a4 and all of a sudden sometimes it will idle fine but then sometimes it idles at like 600rpm in park/neutral and between 4-500rpm in drive, i changed the fuel filter and the o2 sensors since they were old anyway and still no change, the only thing is that the fuel pump is a little noisey, but it has been since i got the car, has anyone had similar problems? anyone think they know wut i should check next? any help is appreciated
Old Nov 10, 2004 | 07:01 PM
Lyle A's Avatar
Re: help! lt1 wont idle right
The IAC controls your idle. Try cleaning the throttle body.
Old Nov 10, 2004 | 07:26 PM
nonojoe66's Avatar
will try that tomorro thanks... i also put a fuel pressure tester on it and it was reading 40 at first and then 30 when it is running... is this normal?
Old Nov 10, 2004 | 07:34 PM
hosspwr94's Avatar
Your fuel pressure sounds low So possibly your regulator is going or your pump is going. Stock fuel pressure at idle should be around 42PSI Correct me if I am wrong but that is what I remember. But that is just my .02 Good luck
Les
Old Nov 10, 2004 | 10:03 PM
mohawkmike's Avatar
try tapping on the IAC while the car is acting up. if the idle changes when you tap it you need an iac.
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
