Help! LT1 over heating
Old Apr 18, 2008 | 06:25 PM
spltblkribbon's Avatar
My 1995 camaro z28 overheats and I just replaced the thermostat, and the radiator tank. Steam keeps coming out of the over flow. Any suggestions where to start?
Old Apr 18, 2008 | 06:30 PM
94zgreenmachine's Avatar
Did you bleed the air out after the t-stat and radiator install?
Old Apr 18, 2008 | 06:32 PM
No I didn't. How do I do that? And the temp gauge kind of goes crazy up and down up and down so I keep the heater on full blast to cool it down a bit.
Old Apr 18, 2008 | 06:39 PM
Eric_96Z's Avatar
Are your fans running?
Old Apr 18, 2008 | 06:45 PM
I cant tell by looking I put my finger down there to feel and I didn't feel anything moving. Any other way to tell?
Old Apr 18, 2008 | 06:49 PM
There are 2 air bleed screws to the system. You need to crack them open till you get coolant to bleed thru without any air bubbles. You can tell when the air is done because there will be a steady stream of coolant. You will need to alternate between the bleed screws. One is near the alternator and the other is closer to the opti. Place a rag under the water pump and over the opti when you do this . Try to keep the coolant off the opti.
If you do this when it is cold, you can start with the coolant cap off. When it gets low, add more. Crack the screws and just keep repeating. When the motor gets to full temp, the t-stat will be fully open . When the coolant streams out and you don't need to add anymore coolant, you are done.
Old Apr 18, 2008 | 06:51 PM
Thank you very much I appreciate it. You think thats suspect for overheating?
Old Apr 18, 2008 | 06:52 PM
and what is opti.?
Old Apr 18, 2008 | 06:59 PM
and what is opti.?
opti is the optispark. Our distributors are known as the opti spark. It gets a bad rap alot of the time but it is buried under the water pump. The bad part is some engineer had the bright idea to put the weep hole in a spot that will leak onto the opti spark. While the opti is a "sealed" unit, sometimes the coolant gets inside and the coolant is very bad for the opti. Thats why I said to cover the opti with a rag. You can get a few drops on it but don't let it get soaking wet with coolant. You will be fine, don't worry.
Old Apr 18, 2008 | 09:05 PM
maverickmk's Avatar
this is the opti - http://shbox.com/1/opti_cyl.jpg it is located behind the water pump
and this is the coolant bleed screws - http://shbox.com/1/bleeders.jpg
Old Apr 19, 2008 | 06:28 AM
SnakeOiler's Avatar
and this is the proper fill method http://shbox.com/1/4th_gen_tech2.html#radflush
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
cristian1311
Nov 23, 2014 02:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
