help... is an LS1 gas tank the same as an LT1 tank?
Old Jan 6, 2003 | 10:15 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation help... is an LS1 gas tank the same as an LT1 tank?
i know the ls1 tanks weigh 20 lbs less than our steel thugs, and i was wondering if they are dimensionally the same and are the pumps retained in the tank the same way?
anyhelp is appreciated!
taner
Old Jan 6, 2003 | 10:23 PM
They are a little bigger and use a completely different fuel pump/pickup/vent system. Don't know if our pump/pickup is adaptable to it.
Old Jan 6, 2003 | 10:27 PM
taner's Avatar
ha ha, i should have just emailed you the question,
thanks!
taner
Old Jan 6, 2003 | 10:44 PM
thanks!
taner
I don't mean to say it is not possible. It just does not look like it would be a direct swap. Maybe someone out there has done it and can give a definitive answer. It's a good question.
Old Jan 6, 2003 | 11:47 PM
Highlander's Avatar
I asked some people from a junkyard and they tried it and not possible...
Some other opinions please
Old Feb 14, 2003 | 07:18 PM
95 Z/28 LT1's Avatar
Super Moderator
TTT. I really want to try this. If it's not a easy swap, then what is interchangeable between the two then?
rideordie
Nov 5, 2019 04:52 PM
Deadbolt24
Jan 19, 2015 01:29 PM
LewisW96
82
Feb 24, 2008 04:49 PM
simple
Aug 11, 2002 11:56 AM
