Help identify mystery box...
Old Jun 19, 2003 | 05:18 PM
ochinkruta's Avatar
Question Help identify mystery box...
I have no clue what this box is...
Mounted onto the panel just above the ALDL connector is another 6 pin connector with a cable routed underneath the knee bolster panel. I removed the panel and the cable leads to a small black box with no identifying marks. It has a small circuit board inside with the output for the connector cable and 3 inputs labelled "starter", "power", and "ground". The power and starter have been spliced into a light green or yellow heavier gauge wire that is obviously part of the chassis wiring harness. Does anyone with some electrical experience have a clue as to what this is? And is there any harm in removing it? I'm no electronics guru as you can see...
Old Jun 19, 2003 | 06:32 PM
PoorMan's Avatar
Does not sound factory. Maybe a remote starter install from a previous owner.
Jeff D
Old Jun 19, 2003 | 06:39 PM
zlightning's Avatar
If no here can tell you for sure what it is I would take it to a local car stereo/alarm shop and see what they think.
14
Aug 11, 2015 12:03 PM
NewsBot
Jul 29, 2015 08:10 PM
cjamen
Jul 27, 2015 12:48 PM
Latronaxe
Jun 10, 2015 02:08 PM
detroit1994z28
May 14, 2015 12:09 AM
