Help i think my trans just went
Old Jun 2, 2003 | 10:43 PM
97f1z28's Avatar
Ok, here is the story. I was driving home from work. I got on the on ramp and gave it some gas. I heard a loud thump that sounded like it came from the rear. I proceeded on the on ramp and everything sounded fine. I figured a rock was thrown up and hit the bottom of the car. Well I went down the expressway and everything seemed fine. When I got of the expressway i slowed for a light. Then when I took off it held first gear and didn't won't to shift into second. It eventually shifted to second and then proceed with out a problem. Then stopped for a light and had to start in first again. It did the same thing it would hold first for a long time and then slowly shift into second. Did my tranny just take a dump and I need to rebuild?
A4 with transgo and a trans cooler.
Thank You
Andy
Old Jun 3, 2003 | 01:15 AM
fbird95's Avatar
Something is definatly starting to go inside the trans, How many miles do you have on your car?
Old Jun 3, 2003 | 05:26 AM
CrippleFightin's Avatar
You said a loud clunk right? Well if thats the case trying replacing the trans mount. If that doesnt solve your problem then you might have something more serious.
Old Jun 3, 2003 | 05:32 AM
97f1z28's Avatar
Trans has 40000 on it. I have had the trans mount break and know what that sounds like. I checked just incase and its fine. Could this be anything else other than my tranny going?
Thanks Andy
Old Jun 4, 2003 | 12:56 AM
fbird95's Avatar
the clunk could be a trans mount, but not shifting defiantly is a inside the trans issue.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
