HELP! I still smell gas inside car!!!
Old Feb 5, 2003 | 12:34 PM
  #16
Originally posted by 97firechicken
If they where bad would that create the smell?
Not unless there is fuel leaking and I doubt there is. The pressure is high there and you would know if you had a leak.
Did you read the post of the guy that said to check the fuel pressure regulator vacuum line? He went on to say that if fuel was getting into the vacuum line, the smell could be drawn into the passenger compartment through the HVAC control lines. Of course if there was fuel in that vacuum line, that would mean that your regulator was bad and needed to be replaced.
Old Feb 5, 2003 | 04:53 PM
  #17
97firechicken's Avatar
No i didnt read that, where is the fuel pressure regulator vacuum line? And Im sorry i having a dumb moment, HVAC always high voltage AC, what does that mean, and i take it the control lines are on the passenger side?
Old Feb 7, 2003 | 12:33 PM
  #18
snksknr94's Avatar
Where is that tub at exactly? and do i have to drop the tank to get to it?
No, you don't have to drop the tank. It is on the driver side, if you stand under the tank, with the car in the air you can see it. It is a white, plastic thing with a hose that runs back up to the top of the tank.
Old Feb 7, 2003 | 01:13 PM
  #19
oldBones's Avatar
Smile
I don't know if it has aready been posted,(don't have time read all of the posts) but did you check your fuel pressure regulator?
Old Feb 7, 2003 | 02:46 PM
  #20
Fuel pressure regulator. You can see the vacuum line that is plugged into it. Pull that off and smell/look for gas in it.
HVAC=heating, ventilation, air conditioning
The controls in the car that move the doors inside the ducting are operated by vacuum routed through this valve. That is why you hear a "hissssssssss" when you change the mode selector on the dash to a different position.
I am not sure what the other guy said about drawing fumes in the car is totally plausible. It might be if it was leaking enough, but it cannot hurt to check
blac94Z
Nov 28, 2014 01:53 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
