getting a code 26 and 77 on my 94
Old Apr 26, 2006 | 02:53 PM
blackztpi's Avatar
I'm getting a code 26 and 77 on my car and i have no idea why. my fans are on a manual switch and I've never had any problems with my evap. any ideas help. btw, searches have done nothing for me so far. thanks
Old Apr 26, 2006 | 02:59 PM
Re: getting a code 26 and 77 on my 94
DTC 26 = Evaporative Emission (EVAP) canister purge solenoid valve circuit
There is a problem with the solenoid or the wiring.
DTC 77 = Cooling fan relay control circuit
It isn't unusual to get the fan code because of the manual switch being added to the circuit.
Old Apr 27, 2006 | 03:11 PM
blackztpi's Avatar
on the evap, there is only one wire that plugs into that thing i believe and it is plugged in. again, i've never had any codes from the fans previously after 5k miles of driving on the manual fan switch setup. do you happen to have a schematic for the fan circuit to the pcm? I'd like to try and hook it back up to the computer. the previous owner had a problem with the fans and half assed the job by putting a switch on it. thanks.
Old Apr 27, 2006 | 05:06 PM
The EVAP solenoid could be burned out (open circuit) or shorted out. Put an ohm meter across the solenoid terminals to check.
There's a diagram of the fan control circuit on Shoebox's Tech Pages. Look at the PCM wiring diagrams. They are for a 95, so they will be different from your 94. I think he has a diagram showing the "early" 95 setups, which should be similar to the 94. There are also diagrams for installing fan switches for both OBD-I and OBD-II:
http://shbox.com/1/schematics_wiring.html
Old Apr 27, 2006 | 10:52 PM
blackztpi's Avatar
do i really need that ecap solenoid? idon't have any emissions on it right now.
Old Apr 28, 2006 | 11:18 AM
You can get some fuel smell buildup in the back of the car near the fill cap, without the EVAP system.
Old Apr 28, 2006 | 10:05 PM
blackztpi's Avatar
where do the evap liones go? the evap solenoid is that one mounted to the drivers side intake manifold, right? i don't have any lines hooked up to that thing.....i can't find any.
Old Apr 29, 2006 | 09:40 AM
The EVAP purge solenoid is on the PASSENGER side, middle of the intake manifold on a bracket. The solenoid on the DRIVER'S side is the EGR vacuum.
Shoebox has all the details on his website:
http://shbox.com/1/evap_system.jpg
Old Jun 9, 2006 | 03:45 PM
blackztpi's Avatar
replaced the evap solenoid and it's still throwing code. i disabled the code through the tunercat program for now, but how can i trace the wiring and see if it is bad? is there aground somewhere?
Old Jun 9, 2006 | 04:05 PM
There are two wires to the EVAP solenoid. The brown wire supplies +12V from the Ignition fuse. The dk green/white wire is the ground, provided by the PCM (pin D10) when it activates the solenoid.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
