Help - engine runs bad when warm
Old Feb 19, 2013 | 10:16 PM
anthonyz281994's Avatar
Ok i have a 1994 camaro z28 with the LT1 and i can start it let it warm up and once it hits about 170 degrees it starts sputtering and if i give it gas it dies. After it dies i can try and start it but all it does is crank. I know its getting fuel and i just replaced the ICM because it tested bad. If i let it cool down it will start up fine and run great until it warms up again and does the same thing. Im on a limited budget and dont want to just start replacing parts PLEASE HELP!!!!!!
Old Feb 20, 2013 | 05:02 PM
parkers Z28's Avatar
Re: Help
Your getting fuel ... but what does your fuel pressure look like ??? is the pressure dropping when
your car starts to sputter ?????
Old Feb 21, 2013 | 12:43 AM
Chet1185's Avatar
Test the opti
Posted from Camaroz28.com App for Android
Old Feb 21, 2013 | 02:11 AM
popo8's Avatar
Re: Help - engine runs bad when warm
What type of icm did u replace the other with.
Did u put some heat grease on the back?
Larry (Popo8) Co-owner
LTXtech.com
Old Feb 21, 2013 | 05:21 AM
Heat soak can also affect the optical cam position sensor in the Opti (sets a code - scan it) or the fuel pump. Measure the fuel pressure. "Getting fuel" doesn't help if it's not at the right pressure.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
Lions3
Apr 11, 2003 10:55 AM
