Help, engine died and will no longer start.
Old Feb 11, 2005 | 12:31 PM
Cerwin Vega Fan's Avatar
Arrow Help, engine died and will no longer start.
I was going down the road and my car backfired really loud, now my car will no longer start. The car tries to start normally but the engine will not turn over. Could anyone help me out here, I inspected under the hood and could not find out what is wrong with it. I filled my car up earlier that day so maybe I could have bad gas?
Old Feb 11, 2005 | 12:39 PM
1-bad-z28's Avatar
Re: Help, engine died and will no longer start.
are you saying the engine will not turn over? or are you saying the engine does turn over but it just won't start?
Old Feb 11, 2005 | 12:41 PM
TraceZ's Avatar
Assuming the starter cranks the motor, You'll need a noid light, spark tester and fuel pressure gauge.
Use the fuel pressure gauge to make sure the fuel rail has pressure
Use the noid light to check for injector pulse
Use the spark tester to make sure the plugs are firing
If you have all 3 of these "ingrediants", it should run.
Is there a SES light?
Old Feb 11, 2005 | 12:44 PM
I can turn the key and it will try to start but the engine will not go.
Old Feb 11, 2005 | 02:36 PM
RED396's Avatar
I have the same problem. I have replaced the Opti, spark plugs, fuel pump, still have the same problem. Opti cable, coil, module, and ecm have been ruled out ( these were swapped out of a running car). Still won't start. I have spark because it backfired once. All it does is turn over and stumble when you let off the key. Help please.
Old Feb 11, 2005 | 02:42 PM
Yeah finding the problem is the hardest part, I dropped the car off at a mechanic (don't have time to fix it) and I'm just going to see if he can find the problem. If the problem is somthing small (like the Opti or coil) I will fix it myself but if it is the timing chain then the mechanic will have to do it (don't have the time to do it). If the mechanic cannot find the problem, any body wanna buy a non working 1995 Z28 Vert with 77K?
Old Feb 11, 2005 | 02:45 PM
NetChemica's Avatar
how much? I might be interested
Old Feb 11, 2005 | 02:48 PM
Originally Posted by NetChemica
how much? I'm interested
3K maybe? First let me try to see if I can find out the what kind of problem I have. I use to brag saying my Opti has worked fine and is in top notch shape, those words may be ccoming back to haunt me.
Old Feb 11, 2005 | 03:19 PM
RED396's Avatar
I forgot the timing chain and gears are replaced too.
Old Feb 11, 2005 | 07:51 PM
RacerChuck's Avatar
I had a 94 LT1 that left me stranded once. Turned out to be the crank trigger that fires the opti.
I've heard that is a common problem with that Gen Engine.
Old Feb 11, 2005 | 10:15 PM
TraceZ's Avatar
94 LT1 cars do not have a crank trigger. Engine position is obtained with the optical wheel pickup within the optispark, based on cam position.
In 1997 OBDII cars were equiped with a crank position sensor. That is why 1997 cars use a different timing cover than other years.
I'm guessing you were refering to the cam position sensor within the opti when you refered to a "crank trigger"?
Old Feb 12, 2005 | 11:40 AM
Turned out it was the coil wire. The coil is corroded so bad the wire is slipping off. When I checked the wire it looked fine so I didn't mess with it but unless the wire is firmly placed on the coil it won't work. I have a new coil on the way and I need to figure out how long of a wire I need for the coil. I think the stock coil wire will be fine for a while, it is just the coil is falling apart.
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Ricardo
Nov 29, 2014 10:58 AM
