Help with electrical or fuel troubles?
Old Aug 10, 2006 | 02:08 PM
ground_pounder's Avatar
My 94' Z is idling rough after the car warms up. The engine is vibrating pretty bad. There is also studdering or hesitation when I am coming to a stop or rolling of the line slowly. There seems to be a power loss at light throttle, open throttle is okay. I can also smell gas. I have a new opti, plugs and wires. I think I might need a new fuel pump? What does everybody else think?
Old Aug 10, 2006 | 11:34 PM
EuroticCustoms's Avatar
Re: Help with electrical or fuel troubles?
Prolly right. If it's not throwing any codes, check the fuel pressure. Here's a good write-up on shoebox's website. It tells pretty much how to troubleshoot the entire fuel system. http://www.shbox.com/1/4th_gen_tech2...essure_testing
Old Aug 12, 2006 | 05:49 AM
Guest47904's Avatar
Guest
Since you smell fuel, it's doubtful the fuel pump is the problem.
Disconnect an O2 and see if it runs good even after it warms up.
Old Aug 12, 2006 | 10:50 AM
Lower's Avatar
How new are the opti, plugs and wires? If the trouble started after replacing them, then that would be where I would start my search.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Mar 24, 2015 08:09 PM
Redbird
Sep 3, 2002 02:08 PM
