help chosing gears?
Old Sep 12, 2017 | 06:32 PM
Lilo Tapia's Avatar
help chosing gears?
i need help chossing gears for my 1997 camaro z28 lt1 6 speed.
i was thinking of 3.73 gears? any suggestions?
also im having hard time finding the right gears that would fit my car if anyone knoes the specifications of the gears im running stock as of now.
Old Sep 12, 2017 | 08:01 PM
Re: help chosing gears?
Recent discussion of 3.73:1 vs. 4.11:1 with the 6-speed manual:
https://www.camaroz28.com/forums/dri...-w-t56-885936/
I would personally recommend the 4.11's.
All 1994-2002 4th Gen F-Bodies with the T56 6-speed manual trans left the factory w/ 3.42:1 rear axle ratio. You can confirm this by looking for the RPO code GU6 on the service parts code tag in the glove box or on the end of the driver's door. Here's more info about your trans and the gears:
4_3
The rear axle assembly is a GM 7.625" 10-bolt. You will need the gear set, install kit, gear lube and GM limited slip differential additive. Self install not recommended unless you have the required tools like a magnetic dial indicator, pinion depth checker, and inch-pound torque wrench.
Old Sep 12, 2017 | 08:07 PM
Lilo Tapia's Avatar
Thank you.
Old Sep 12, 2017 | 10:11 PM
Wimmer's Avatar
had a head cam 96 ws6 6 speed loved 410s!
Old Sep 13, 2017 | 04:43 PM
94Z28LS1toLT1's Avatar
Nice ride,i just got the 4:10 gears in my 94 lt1 m6,and they are awesome
Old Sep 13, 2017 | 06:57 PM
87Aerocoupe's Avatar
You'll also need to have your pcm reprogrammed for whatever gear set you install and I would also vote 4.10's or 4.30's with a m6.
Old Sep 27, 2017 | 11:30 AM
Lilo Tapia's Avatar
i dont have the rpo codes to see if i have a 2 series or 3 series gears .. anyone know with gears ill have 97 lt1 6speed t56?
Old Sep 27, 2017 | 12:49 PM
Lilo Tapia's Avatar
what does m6 mean? thanks
Old Sep 27, 2017 | 02:02 PM
Thought that was clear in the earlier post. 3-series carrier.
Originally Posted by Injuneer
....... All 1994-2002 4th Gen F-Bodies with the T56 6-speed manual trans left the factory w/ 3.42:1 rear axle ratio. You can confirm this by looking for the RPO code GU6 on the service parts code tag in the glove box or on the end of the driver's door......
That assumes a previous owner did not already change the gear ratio.
M6 = Manual 6-speed transmission = T56 made by Borg Warner and later Tremec. = the transmission in your car.
Old Sep 28, 2017 | 10:37 PM
so what gears did u end up getting?
