help! cc306 cam install
Old Jun 29, 2003 | 05:03 PM
CamZ2811's Avatar
Angry help! cc306 cam install
I'm installing a Comp cc306 cam in my '95 Z28(OBD1) the dial pin in the end of the cam is longer and looks like a smaller diameter than the dial pin in my stock cam. I called Comp to see if I got the wrong cam. Comp said that they only make one cc306 cam for '93-'97 lt1s. Will the pin size efect any thing? Do I need the pin cut, machined or what? No one seams to be able to give me a good anser. Thanx!!!
By the way this is my first time to open a motor so any other tips or suggestions yall got send'em my way.
Old Jun 29, 2003 | 06:33 PM
MZK4252's Avatar
There is a difference in the 93-95 and 96-97 cam dowel lengths. I believe that this is due to the existance of the crank position sensor on the later models (or maybe the vented opti). I have only seen mine (95 no PCS) so I don't know which one you have, but I'm sure someone around here can answer that, so hopefully someone else will be able to help more than I can.
Old Jun 29, 2003 | 06:48 PM
turbo_Z's Avatar
not a big deal.. just cut or grind the dowel pin down to match the stock cam.
Old Jun 29, 2003 | 07:20 PM
CamZ2811's Avatar
its about time
That's all I needed to know!
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
