HELP! car wont shift, good clutch + tranny!
On the way home today I went to shift into 4th and it wouldn't go, I then tried back into 3rd, no go, let go of clutch pumped it twice, still no go! Then I coasted to a side street and stopped. I tried from a stop and could not get it into any gear, so i turned the car off and on and still could not! I then turned the car off again, it shifted just fine into all gears with clutch pressed and car off, so I put it into first and started the car (leaving the clutch in ofcourse) I heard some very strange sounds that are hard to describe and the car hesitated to start, after that everything was fine. I dont want this to happen again what could have been the problem??
Re: HELP! car wont shift, good clutch + tranny!
It could be several things.I had about the same thing happen to me. It turned out to the shift fork in the transmission on my 94 Z28. I also had a 94 Formula Firebird that a roll pin broke inside the transmission that caused it not shift. My advise is when you find the the problem, get a better shifter if you do not all ready have one. I bought a Hurst billet shifter for mine and it 100% better now. Before if I was shifting hard (like racing) I would miss 3rd gear often now that is totally eliminated.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
